RCU Forums - View Single Post - Avistar Power Question
Old 04-26-2006 | 07:52 PM
CrashBurn69
Default RE: Avistar Power Question
12x8 is the smallest prop the manufacturer recomends. If you can get enough gear clearance you would do ok. You might go with an 11x10 with richening on the top end, but the plane would be a rocket in the sky. You might have to bend the gear a little bit.
