RCU Forums - View Single Post - TF Spitfire Build (Gold Kit)
Old 04-26-2006 | 09:48 PM
tubig
Default RE: TF Spitfire Build (Gold Kit)
ORIGINAL: rgrella
Tubig,
Thanks for the pointer, i will do it. I do have a question, what do you use to make the steam? How do you apply it? Any pointers here would be great..
ray, i just use a regular tea kettle and slowly move the surface a couple of inches above the steam. i move it at about 1 inch/second but sometimes i'll momentarily pause the surface over the steam if the dent is deep/large. keep in mind that if the surface has been cut, gouged or punctured then steam is not going to help. only where the balsa has been "flattened". another method is to apply a damp cloth on the surface and use an iron to create the steam.
