RCU Forums - View Single Post - What is the most efficient air compression method?
Old 04-27-2006 | 12:53 AM
Ldalmas
Default RE: What is the most efficient air compression method?
i meen flow or pressure ?
ifyou need alot of flow and no pressure a supercharger centrifugal is good
if you need flow and some pressure screw type or a roots blower (used in old small engines)
if you need alot of pressure and little flow a piston conpressure is best
depends on your aplication all are effichiant in thair way
