RE: battery question
As long as you only use a 7.4v bat, you can use a higher Mah rating. The problem you will run into is placing the larger size packs into the battery harness. Longer times means harder wear to the engines, so let those motors cool between flights. I was told to fly for a few minutes, then let it rest for a few for peak motor performance.
