Jack211
Yes Bill R. did mention the velocity stack & filter. Unfortunately with the carb offset the way it is in the 72 & 82s there is not enough room between the carb & motor mount. Dang!
Winds were running 8 to 14 mph last night, so I decided to get my grass cut and go fly tonight. I know UCDs fly great in the wind, but its to early in the season to take chances at least untill I get the rest of my planes ready to fly. If I could only fly & cut grass at the same time.
raideron No your fine at 2 turns. 2 to 3 seems about norm depending on tank and line lengths, inverted
or not. If your worried about engine leaning out as tanks empties, chk out this set-up for a uniflw set-up.
http://www.fraserker.com/heli/uniflo...flow_works.htm courtesy of kaastrup.
Doug
