RE: Tower Pro Brushless ESC's
Troy-RCU,
I was running it mostly on high as I wanted to determine if the combination was powerfull enough to pull the plane up when I was on full throttle and pointing the plane skyward. Also, I could see the ESC getting hot when running the motor due to amp draw but why would it get hot when actuating the servos? Seems a bit odd to me but then again this is only my second electric plane.
