RE: Tower Pro Brushless ESC's
Thanks Tony,
That answers my question. I was begining to suspect that I could not run 4 servos while using a 3S Lipo. I guess I'll need to disable the BEC and install an RX battery. I checked the operation again and found that if I just ran the motor a few times for 5 to 10 seconds the ESC did not get very warm but if I actuated the servos it would get hot and especially in a certain area which is probably the BEC circuit you had mentioned.
Thanks Again
