RE: Almost Absolutely Perfect!
they only light when the ignitor is on them, the heat range of the plug has the do with the length of the plug, longer plug is hotter shorter is cooler. Hot plug will make engine run hotter. Always good to try to use different plugs. i like cooler plugs, and richer engines unless i am racing someone.
