RCU Forums - View Single Post - just got the
Thread: just got the
Old 04-28-2006 | 11:21 PM
Super_Dave's Avatar
Super_Dave
Default RE: just got the
Yup thats how I break mine in most of the time. Then get faster every tank untill your at full throttle and final tunning on the 6th tank. Just make sure you get temps up to 200 degrees ASAP and try to keep it below 220.
Only use one gasket for the glow plug. Your supost to replace the gaskets after you take the plug out so ofna gives you an extra for a replacement. The gaskets squish a little when you tighten the plug down and by using it twice will mean it will squish more give you more compression. I never bothered to replace them this way but it wouldn't hurt to do so... but it wont hurt not to either.
