RCU Forums - View Single Post - VS Tank Pro M1A2 Abrams
Old 04-29-2006 | 03:15 PM
condor11
Default RE: VS Tank Pro M1A2 Abrams
ORIGINAL: Gaizokubanou
I got Vs Tank Pro M1A2 as well, and I'm also having trouble with forward turning on off road or on thick carpets. From what I've observed so far, it seems that reverse throttle is always at maximum power, so the tank has no problem turning in reverse, but forward turning is capped at 2/3, which basically makes it un-turnable on any rough terrain... Also one of my suspension seem to have been broken already
Yep, same here. My Leopard 2 turns a lot better than Abrams. Mind you Abrams turns fine at second speed, but I alwys like to turn on the lowest setting. Overall leopard is a better tank probably because it was released after Abrams and they probably added improvements.
