ORIGINAL: grasshopper31
...i think even with the slightest breeze, this thing is affected. even when i try to work on ground handling through taxi practice, the tail gets blown around with the slightest breeze. should i add weight and re-adjust the CG again to hold it down better? i think it only weighs about 4 pounds total. maybe a couple ounces more.
That sensitivity sounds like you need toe-in. Hopefully, the CG is set where the manufacturer recommended it to be?[&:]
