RCU Forums - View Single Post - Motor ?
Thread: Motor ?
Old 04-29-2006 | 07:23 PM
scrapheep
Default RE: Motor ?
First off... a broken in engine has no pinch, it has compression...or lack thereof if it is used up.
The only accurate ways of determining the state of the engine would be a compression check,leakdown test, or good ol fashioned thrash on it and see if you can get her tuned.
Compression checks/leakdown tests should only be done when the engine is cold.
