ORIGINAL: Gaizokubanou
Ah so you have both Leo2 and Abrams? Could you check if Abrams have higher ground clearance than Leo? Cause I read somewhere that Abrams had higher ground clearance, but if they are similar in ground clearance, I'll be getting a Leo next for sure.
Abrams does have a bit higher ground clearance. Maybe 2-3mm difference. One other thing - when going over high hill with one track (when the tank banks) Abrams won't throw track while Leo might. And it also doesn't have mudflaps in the mack so it can go over rought terrain better than Leo.
Still I won't be getting more Abrams's. Overall turning performance is still worse and lack of lights makes it look less realistic. Plus I really like overall looks of Leo. German engineering
