RE: Glue the Block In?
definitely epoxy it in. If you're not using them already, I'd use nylon gear bolts also. Using metal ones is just asking to get your gear block (and maybe more) torn out on a botched landing. With the nylon bolts your gear will just shear off the bolt heads and not damage the mounting block.
