RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 04-30-2006 | 03:45 AM
  #4496
crank
Default RE: U-Can-Do 3d 46?
Hello all!
Maidened my ucd 46 with S100 today! WOW WOW WOW! Very impressed by this combo! And I would say that it does not feel as ugly overpowered. It hadles very easy.
Saito now swings APC15X4W on 20% BYRON fuel and I limit it to 9700RPM. Dry weight is 2860g (no pants). Many thanks gjeffers for the info regarding saito 100 installation. The only thing I made differently than in gjeffers installation is reverse of one engine mount bolt nearest to the carb. The nut is outside. The bolt is tighten from within the fuse using long screwdriver. See the pic. That trick allowed to shift engine closer to the firewall another 6mm.
