RE: Glue the Block In?
Definitely epoxy. With the nylon bolts, make sure that when you tighten them in, go at least 1/8-1/4 turn past the point where the bolt is feeling tension. This is necessary to preload the bolt. If you don't, they won't shear off properly when they need to.
Brad
