RCU Forums - View Single Post - Jet Central Flea??
Old 04-30-2006 | 07:19 PM
  #135
747drvr's Avatar
747drvr
Default RE: Jet Central Flea??
Where did you get these numbers ? There is NO way that it has 1.5 kgs ,or lbs for that matter , at idle. Just checked my test stand numbers and I'm getting 2lbs at 128K , 4 lbs at 160k and 6 lbs at 180k . Full throttle thrust was 8 lbs 4 oz . Temps were very low as well . Only 490 deg at full .
Marc
ORIGINAL: littlepiston
MW 44 well the oly thing that sucks is the 3LB thrust at idle ,,i will still be flying hehehe
MW44 gold specification
Maximum thrust 3.6Kg at 195,000 rpm.
Idle thrust 1.5Kg at 50,000 rpm
Exhaust temperature at maximum 520-700 degrees C
Fuel consumption at maximum 140 ml/min at 195,000 rpm
Length 135mm (no onboard starter )
Diameter 75mm
Weight 468 g bare engine only
Hand start engine 680g with ecu battery etc
Onboard start engine 770g with ecu battery etc
Autostart engine with 2 valves 890g with ecu battery etc
