RE: BRIO Electric 10-size
I am still working on my Brio 10.
Anyone have problem with different wing panel lengths?
After spending more than two hours to remove warps on ailerons, hinging, servo installations etc on wings, I just tried to measure the distance from wing tips to the vertical stab. about 1/8" difference.
Hinge lines are not all correct. after gluing the hinges on elevator, I found that the elevator is about 1/32" lower than the horizontal stab.[>:] I will never watch TV while working on a plane.
bdavidson,
any problem on setting up the rudder Pull-Pull? I am going to replace the wire with Kevlar.
What is your power setup? I am using 6 series and have no idea how long the thrust washer of the gear box should be from the firewall. It looks a little too short when I trial fit.
Ihncheol Park
P & A Hobbies
