RE: COMPRESION RATIO CALC HELP??
Two stroke compression is generally figured from the exhaust port closing. However, it is consequently therefore a lower number than we are used to seeing in four stroke engines which are of course calculated full stroke. If you have 12:1 compression figured from exhaust port closing, I don't think the engine will last very long!!
AV8TOR
