RCU Forums - View Single Post - Stuck wing help
Old 05-01-2006 | 07:45 AM
DonStegall's Avatar
DonStegall
Default RE: Stuck wing help
Dave,
Sorry to hear that. I'm still dealing with the fallout of some stuck parts.
It sounds like you will have to destroy the part. That is a small loss compared to the mold.
If you used Rohacell, you probably want to pull out the inner layer of glass, leaving some foam and one layer of glass.
Depending on how bad it is stuck, you may be able to use an artist's spatula to chip the paint/glass away from the mold.
If you can get the outer layer of glass out, chipping the paint loose is easier. I have used a 1/2" chisel to get the glass out. It is time consuming, but with care it can be done.
Worst case, you can ship it to me and Matthew and I will work on it.
Don Stegall
RCPRO
