RCU Forums - View Single Post - Peter Barth Waco
Old 05-01-2006 | 01:52 PM
  #83
chuck l
My Feedback: (17)
Default RE: Peter Barth Waco
Marko,
Could you look at the attached pictures, the lower aileron will only deflect 20 degrees down whereas the upper aileron will move 30 degrees. In the up position they both exceed 45 degrees. In the down position, the upper aileron is resting against the trailing edge of the wing, and the lower aileron still has a gap. Without the upper aileron attached, the lower aileron will easily get to 30 degrees. From your pictures, your ailerons look to move equally in the down position. Can you give me some suggestions to corrects this.
Chuck
ID:	453765   Click image for larger version
ID:	453766   Click image for larger version
ID:	453767   Click image for larger version
