ORIGINAL: flytime56
thanks for all the e-mails. Are there additional ways I can ground the ignition unit to the engine? running an additional cable from ignition unit to one of the mounting bolts.
That's all thats needed.
Normally ignition units are grounded thru the shield on the spark plug lead. If that does not make good contact you will have problems. Running an additional wire from the case of the ignition unit to the mounting lug will help in that case
