RE: NEW Hobbyzone Firebird Freedom
I've noticed the same thing on mine turning in the wind. Here's something even more odd that I ran into last night - turning into the wind. I noticed my plane was VERY responsive turning left, but no so much turning right. I brought it in and lo and behold when I swapped out the tail, I had the left horn on the lower hole and the right horn on the upper hole. So I thought that if I put the right on the lower hole, I'd get more demand on that flap as well. Wrong, both on the lower holes made the plane fly terribly. I can't even begin to understand what was going on. How the heck could I loop correctly w/ different throws on the flaps? I'm starting to believe that the servos/set up on the freedom just doesn't like those lower holes. This is my 2nd attempt to move to the lower ones w/ bad results.
