RCU Forums - View Single Post - In flight RPM
Thread: In flight RPM
Old 12-17-2002 | 12:56 AM
edge_fanatic
Default Have no clue either....
But I'd have figured a few hundred, maybe three hundred....If 1000, then a YS 140L at 8000 on the ground would be in danger in the air, if I recall their specs correctly.
I'd also expect that the difference will vary a bit based on temp and altitude (unless the relationship between tem, altitude and RPM is linear...which I doubt).
But I am guessing...heh
