RCU Forums - View Single Post - Question About A Rudder Pull-Pull System?
Old 05-02-2006 | 11:09 AM
SaCCaL72
Default Question About A Rudder Pull-Pull System?
I installed my first pull-pull system on a Aeroworks Edge 540T and I just had a question about how it should be set up. Should the cables that go from the servo to the rudder be really taut or should they be a little looser when in the neutral position? Is there a such thing as too tight or is tighter better? Thanks in advance for your help...
