RE: Oh jeez...
Start from the basics. Check to see if your carb opening is suffice for idle speeds. Gotta use new plugs of course, use FRESH fuel... then go from there.
They need 3 things to start. Air/fuel mixture, compression, and HEAT to get the ignition of the air/fuel mixture.
