RCU Forums - View Single Post - BME 110 owners
Old 05-03-2006 | 09:32 AM
Modified's Avatar
Modified
Default RE: BME 110 owners
ORIGINAL: tande
Hi Dave!---I had the same problem on a BME 110 & also two YW 48---Drove me crazy!, turned out to be a "Lean" high/mid-range fuel mix---Even tried different ign. timing advance/retard curves---For me, lowering the metering lever spring pressure & a richer HS needle setting, solved the problem---Hope this helps---
This fixed mine also.
