RE: gas fuel with glo plug no ignition
Hey guys im into this conversion scene, but from an alternate angle.
Mine is for marine applications. As you guys would know, rpm is everything when chasing speed in a boat.
I have an 18.4cc weedeater, bog stock for now.
The prop i want to spin is a 65mm 95,1mm pitch octura prop.
I was wondering whether you guys see any advantage in doin all these mods to a marine motor, where weight is LESS of an issue then in an aeroplane?
On another note, i will have an advantage, of a watercooled head so perhaps if i go ahead with a gas + glow setup i may have some cooling advantages, in chasing rpms.
On a side note though, am i better off ditchin the 18.4 and goin to a 25cc GMC 2stroke motor (looks like a ryobi or homey cant b sure?)
Its going to be heading into a 50" apache style deep vee hull (if that means anythin) with a surface drive prop (only partially submerged, makes engine rev out more easily)
THanks guyz,
Ben
