RCU Forums - View Single Post - Monokote Blues
Old 05-03-2006 | 03:52 PM
tuwood's Avatar
tuwood
Default RE: Monokote Blues
ORIGINAL: Dr1Driver
Hi fellow airheads!
Actually, it's not Monokote Blue, it's True Red. I built a Sig Kadet LT-40 kit for fun and profit (mostly profit). I decided to cover it in a red/white/blue scheme, just to make it different (and prettier) than your standard Kadet.
I already had Ultracote white and blue. I liked the Monokote True Red against the blue better than the Ultrcote red, so, against my better judgment, I bought a roll.
I'm covering the red/white stripes on the top of the wing now. It seems that Top Flite has the "shrink" setting dialed up to just under "strip paint". In fact, I have a paint stripper I seriously considered using. My Coverite Black Baron iron is turned up to around 350 to attach the edges, and my heat gun is working overtime. It takes an obvious color change of the Monokote to actually shrink it, and I'm holding the gun in one place a LONG time. It's a big PITA.
I'm seriously glad this will be the LAST plane I cover with Monokote.
To those who use and get good results with Monokote, more power to ya.
Just venting a little.
Dr.1
I really need to try Ultracote sometime. I've covered 2 planes with monokote & they both turned out great and I truly enjoyed working with it. I half wonder if I would struggle using Ultracote because I'm used to working with Monokote.
I think the color selection is one of the things that drove me to Monokote in the first place. I could never find colors I liked in Ultracote.
Anyway, hope it's an easy fix and you can get the color scheme you wanted.
Tony
