RE: ANOTHER BTE VENTURE BUILD
I built the right wing last night in about 3 hours. I layed everything out dry to make sure I had it all right and all the pieces were there. All went very well and yes, I did place the holes in the ribs for the servo wire for the ailerons as well as the ones that are recommended to allow heat to escape when covering. Tonight I want to reglue all of my joints with medium CA and lay out the servo bay. I didn't sheet the bottom of the wing as yet due to having to place the block for the wing dowels. If it isn't too late I will start on the left wing in the hope of getting it close to completion. Question..is it better to wait until the covering in on before you make the slots for the hinges?
