RCU Forums - View Single Post - GP ULTIMATE 160/WHAT ENGINE SHOULD I USE????
Old 05-04-2006 | 10:15 AM
bubbagates's Avatar
bubbagates
My Feedback: (32)
Default RE: GP ULTIMATE 160/WHAT ENGINE SHOULD I USE????
ORIGINAL: BSR
i see you used a brisson \what prop are you using with bipe just orderd one. took motor off mig 3 that hasent flown yet . have you flown plane yet. and have you had any problems with rfi as of yet
I started out on the MSC 22x8 and just changed to the Mezjlik 23X8 since I have over 6 gallons through it now. Start out of the MSC 22X8 if the engine is not broken in. When I first got mine it was turning the 22X* at just over 7000, now it turns it at just under 7300. I switched props and am turning 7200 even and have even more pull than I did before and with the 22X8 the pull was great
I have had no problems at all with RFI. Just do the standard RFI practices and you will be fine
