RCU Forums - View Single Post - Sniper Setup
Thread: Sniper Setup
Old 05-04-2006 | 10:30 AM
dbateman
My Feedback: (31)
Default RE: Sniper Setup
Skymac, you should post in the EDF forum , or check out RCGroups. The Sniper is a nice little jet and will go like a rocket if properly equipped. But there is barely enough room for the basic equipment. If you try to add retracts and rudder you will have a problem. It's all about weight with edf's. You might want to look at the 90 mm size jets [ the next size up ]. Jepe , Aeronaut makes some nice stuff. Check out warbirds.com or ductedfans.com. Doug
