In a conventional aircraft layout (stab behind wing, engine up front...) the horizontal stab's function in level flight is to push down on the tail and not to produce "lift." This is assuming that the aircraft's center of gravity is forward of the neutral point on the wing. If the center on gravity is behind the neutral point, not only will the stab need to lift the tail, but the pilot will also likely need a diaper.
