What type of servos?
All servos designed for RC use are interchangable, as long as they have an appropriate plug. The signal sent from the receiver to the servo is the same, regardless of the brand or transmittion method (AM / FM-PPM / FM-PCM).
What type of receiver do you have? Hitec as well? If so, any servo with a universal connector should work.
