RCU Forums - View Single Post - HARMON ROCKET
Old 05-05-2006 | 07:35 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: HARMON ROCKET
kmalsom, First off, when you say, "I try to recover" (I assume you mean from the bounce), are you doing it with elevator? If so, that is incorrect. You should add throttle.
Second: Try adding a little tail weight. a plane that will not slow down for landing is usually a bit nose heavy (Regardless of where it is balanced according to the manual)
