RE: FLITON EDGE 540 FREESTYLE they did it again
You are welcome. Now I just have to get the little EF Extra off the bench and into the air so that I can get started!
I posted that pic of the recommended way to run the elevator halves because I didn't especially like it. Hoping someone will show me how to hook up the halves and run a pull-pull on the elevator...or some other solution. The rudder servo goes under the fuse in the tail and is already setup to be pull-pull. Also, not totally convinced on the wing attachment: Calls for rubber bands holding the wings on... Steve
