ORIGINAL: alpsat
I made a pull pull elevator set up for the extra. It is solid and and lighter than the stock setup as you can get rid of the wood dowel and wires. Just like most pattern planes you should put the elevator servo sideways for the perfect geometry. As I lost my extra because of a battery failure, I cannot get a picture of the servo. It was really a perfect flying plane. Fortunately my edge is on the way and I will make the same setup and power it with YS63s.
Sweet! That's what I was looking for. How did you join the elevator halves? and approximately where did you place the elevator and rudder servos? One more question: Did you use Dubro, or Sullivan hardware?...or does it matter? THanks in advance, Steve
