RCU Forums - View Single Post - engine conversion
Old 05-06-2006 | 07:58 AM
karolh
Default RE: engine conversion
Are you sure that the wing area you quoted is correct, as it does seem a bit low for a model of that size and weight.
I recently started a post on this forum on 'Thrust to weight ratio' for sport / aerobatic models in this size range. Use the search feature and see the comments made, which I found to be most informative.
Karol
