ORIGINAL: Kemo
15-18? I wouldn't really justify that as a braggin right for a truck. The rusty is extremely slow on take off, on a track. the rest of the trucks must be have been equipped with "economy" gear. Almost every truck here has an italian mill in them, or an OS.
Do you even run a setup? or even know how to set the truck up for the track?
this is true, only way a rusty will take off fast is if you run lean or change the gearing. i get ok acceleration but i also got a 360 stinger on it so that brings the low end down and the high end up. but rusty's arent meant for racing because when you jump them the nose just falls straight forward so you have to correct it, and somtimes you cant. so i agree with you
