Sweet! That's what I was looking for. How did you join the elevator halves? and approximately where did you place the elevator and rudder servos? One more question: Did you use Dubro, or Sullivan hardware?...or does it matter? THanks in advance, Steve
I believe either dubro or sullivan will be ok. I just used nylon horns for keeping the weight down. You do not need the join the elevator halves, you should make the same setup for both halves and tie them to the same elevator servo which is placed sideways in the middle, aft of rudder servo. A picture could worth a lot but unfortunately I can not supply one. In the extra there were three servo cut outs on the servo tray ( one on the front two on the back) and the one on the front was in the middle that I used for rudder. I placed the elevator servo just behind it. As far as I see the servo tray on the edge should be modified for this setup.
