ORIGINAL: av8tor1977
Yep. That's exactly right. I've done it many times. Gasahol is not recommended for use in aircraft, nor ultralight aircraft engines. In the ultralights with their two stroke engines, there is sometimes problems with the gasahol absorbing water, and then the oil not mixing properly. Result... the pilots "air conditioner" seizes and quits and he instantly starts sweating!!
AV8TOR
THats unless it has an oil injection pump 8-)
