RE: engine help needed!
You must not twist two wires together to extend the antenna length. Instead buy the whole wire and solder it back in to place on the receiver. Once you have that fixed we can help tuning your engine.
Although, I do believe you have a linkage problem or the idle screw is not properly set as the engine should idle while the servo is centered.
Ryan
