RE: Midwest Extra 300xs Build
Ok, I'm gonna list the component choices I have made for this plane in the hopes that if I have made a mistake on any of the choices that someone here will speak up and say so. I have done quite a bit of research on RCU forums as well as others. In fact it was on RCU that I found out that my first choice for servo's on this plane was a poor one at best (earlier in the thread). Even though I have done lots of research, I am still and will always be capable of poor decisions, given that I am still somewhat a beginner. Keep in mind that this is my first gas plane and I did this setup with a prideful mind (really want to get this right). Some of it is overkill I know, but keeping safety in mind maybe not.
The final decision that I have to make on this build is weight dependent, and that would be to use Koverall for the skin and do an airbrush paint job. I have not made that one yet but will soon as I get the total weight without covering. I am trying to keep the weight below 16#'s. If It's possible to put the plane on a diet to make it work, then I will. If not then I will proceed with Ultracoat. I am in no great hurry as I have already spent the better part of 6 months building this plane. One other thing I need to decide and that is weather or not to install a choke servo.
With all that being said, heres the list:
Brison 3.2
MSC 22 x 8 prop
Dave Brown 3-1/4" spinner
Futaba R319 DPS PCM receiver
HS5945 -
(2) elevator
(2) ailerons
(1) rudder
HS925- throttle
SWB 1-1/4" servo arms all except rudder
SWB 3" Double arm for rudder
(3) Cermark DSC Superswitch
SmartFly optical ignition cutoff
(2) NOBS NIMH 1950 6V receiver battery
(1) NOBS NIMH 1100 6V ignition battery
Dubro 20 oz fuel tank w/PSP tank cap
Kavan 3-1/2" wheels
Stans Fiber Tech Cowl and wheel pants
