RCU Forums - View Single Post - Walkera Dragonfly 22E Sim Cable Help
Old 05-07-2006 | 08:39 PM
Ippie
Default RE: Walkera Dragonfly 22E Sim Cable Help
ORIGINAL: oops
Hi Ippie,
Yes, it does.
As long as you use PPJOY, the TX becomes another HID (Human Interface Device) under XP.
Although the controls are a little messed up by default, if you play with the settings under PPJOY and remap the axis, then your TX works just like a normal joystick.
Well, 2 joysticks... X,Y,Z and Rudder. You can use it with any games under XP - even non-flight-sims,
David
Hi David,
I think the XP has detected the new hardware as the PPJOY or HID.
But I'm not sure how to do the setting on the Mapping as I have mentioned in the other posts here.
