Hi Ippie,
ORIGINAL: Ippie
ORIGINAL: oops
Hi Ippie,
Yes, it does.
As long as you use PPJOY, the TX becomes another HID (Human Interface Device) under XP.
Although the controls are a little messed up by default, if you play with the settings under PPJOY and remap the axis, then your TX works just like a normal joystick.
Well, 2 joysticks... X,Y,Z and Rudder. You can use it with any games under XP - even non-flight-sims,
David
Hi David,
I think the XP has detected the new hardware as the PPJOY or HID.
But I'm not sure how to do the setting on the Mapping as I have mentioned in the other posts here.
It will show up and work under "Game Controllers" when set up correctly.
Don't forget to enable assigned interrupts and configure interrupts under device manager for LPT1 under configuration 0001 or similar.
Tail 4
Nick 2 Inv
Roll 3 Inv
Pitch 1 Inv
Don't forget to set the PPJOY controller as default.
David
