RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 05-08-2006 | 07:22 AM
  #642
av8tor1977's Avatar
av8tor1977
Default RE: gas fuel with glo plug no ignition
Yeah, oil injection helps with that problem, but the alcohol in the gas effectively leans out the mixture throwing your jetting off. (In the wrong direction I might add.) So if you are jetted according to the manufacturer for a particular altittude and temperature, you are going to be leaner, (and more dangerous) for the engine than you think.
AV8TOR
