RE: Latest Restoration
Hello RRyan
As mentioned in one of the above letters the outside shape of the cooling fins were a bit different - in a later version.
The one you have is the original one.
Even earlier the backplate was different - and had a 2-piece NV assembly.
The hexagonal bolts for assembly were used in the 60's.
My own MACH 1 is from -55 and still running very fast - which was a trademark of the MACH 1.
Later there came a glowversion which was less succesfull than the diesel.
Use this fuel - and it will run : 30 % castor + 35 % kerosene + 34 & ether + 1 % amylnitrit or -nitrate.
Put on a wellbalanced light prop f. ex. a 8 x 4 Tornado plasicote woodpropeller and you will enjoy !!
My complments for your work.
KR
hld - OY-9901
