gaas engine detonation?
Two-strokes will detonate if the timing is too far advanced, compression ratio too high, excessive carbon deposits in the combustion chamber, spark plug heat range is too hot, octane of the gas too low, if the cylinder temperature gets too high, or if the load is too high. Premix oil in the gas also lowers the effective octane of the mixture.
