RE: Official Mayhem Thread
well if you have read the fourm you will know that you need to grind the flywheel opening.also buy the pro motor mounts so that it will clear the starter wheel do this by grinding a 45 degree angle edge around the hole.secondly if you have adjusted your idle screw you have probaly done so with the hsn and even the low speed needle.in any case put them all back to the factort settins and go from there.
