RCU Forums - View Single Post - how do you know when the ignition is on?
Old 05-08-2006 | 09:59 PM
Bob101
Default RE: how do you know when the ignition is on?
ORIGINAL: erikpmort
thanks guys i got it fired up tonight.
Guys do the ignition units get hot? I read in the 3w manual that you are supposed to mount with grommets that make sure the back of the unit gets air.... before i read that i double sided taped it and used two screws to secure it to the inside of the fuse.
Mount it on the grommets or mount it over a hole or it will get hot.
